2002 XJR Driver's door actuator
Old Feb 11, 2015 | 03:05 AM
brian2891's Avatar
Default 2002 XJR Driver's door actuator
My driver's side door wouldn't open/unlock from the inside or outside. I ended buying a used latch assembly and replacing it myself. Now, the door still won't open using the inside door handle AND, when I pull on the driver's side door handle, it locks all of the other doors, but still doesn't open the driver's door.
Any suggestions on how to fix this issue?
Old Feb 11, 2015 | 05:04 AM
Vector's Avatar
The actuating cable is broken where it enters the latch. It is a common failure. A search of the forum will turn up quite a few post with info on how to repair.
Vector
Old Feb 11, 2015 | 11:59 PM
brian2891's Avatar
I checked the actuating cable (from the door handle to the latch) and it appears to still be in tact as the end is still on. When I pull on the handle, I can hear the latch pulling, but it the door still won't open. When I would pull on it before, the doors would actually unlock. Now, the other doors lock when I try to open the driver's door from inside
99xk8guy
Sep 29, 2025 10:51 PM
way2far
Aug 31, 2022 09:26 AM
XJsc-guy
Nov 23, 2015 01:56 PM
XJsc-guy
Sep 25, 2015 11:09 AM
philwarner
Sep 3, 2015 10:14 PM
