2003 Jag XJ-8 ANTI THEFT ISSUE? Please read !
My car cranks fast but will not start. My mechanic thinks this is due to the anti theft system being on. A new transponder key had to be made and the locksmith who made it swears it is fine. The car ,before the key issue, would periodically fast crank and not start but on a restart it would turn over. The red led is not on in the console, and I need my new fob programmed. Does this sound like an anti theft issue and if yes, what can be done to resolve it? Thank you for your time....I am so frustrated not having the car running...as you can imagine !!! The dealer wants $200 to diagnose the car and none of that goes toward the repair.....of course...
Search for "bore wash". Stolen from avern1: "The easiest cure for bore wash is to hold the throttle fully to the floor and crank the engine for about 3 to 5 seconds. Do this 3 or 4 times then hold the throttle part way and crank the engine to start. When the throttle is fully depressed on start up it shuts the fuel off to the injectors and allows the cylinders to clear. Crank adds oil to the interior of the engine. This method works to prevent knock sensor damage and all of that lovely smoke"
xjrwithproblems
02-19-2021 08:21 AM
JimC64
11-22-2012 07:26 AM
soonerpride316
06-12-2010 08:15 AM
chriscowan
01-14-2010 05:05 AM
