2003 VDP electrical problem: Body Control Module or Security Module?
Old Nov 28, 2011 | 02:11 PM
Bufcat's Avatar
Default 2003 VDP electrical problem: Body Control Module or Security Module?
I have 2003 VDP which won't pass inspection because the tail lamps are not working. They fail to light up in any switch position. My local mechanic diagnosed it as a Body Control Module failure, but I heard from a Coventry West guy that in all his years of experience, it must be the Security Module? Its expensive to buy the right module, but more expensive if I buy the wrong module.
Old Nov 28, 2011 | 03:34 PM
Gus's Avatar
Gus
First check and see if you have a bad ground for your lights.
Old Dec 1, 2011 | 05:21 PM
Bufcat's Avatar
I have determined that it is not a bad ground. Is there a way to isolate the problem either as BCM or Security module?
-Bufcat
2003 VDP
118,000 miles 4.0 V8
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
XJsc-guy
Nov 23, 2015 01:56 PM
XJsc-guy
Sep 25, 2015 11:09 AM
