2003 XJ8 Can Read Codes, Can’t Clear Them...
Old Dec 19, 2020 | 09:57 PM
Swagger XC's Avatar
Default 2003 XJ8 Can Read Codes, Can’t Clear Them...
Hello!
I just acquired a 2003 XJ8 for winter beater duty (long story) and today the resonator part of the intake broke off triggering a p0138 code and rough running. Easy enough I thought to replace the the pipe with a new one and then clear the code.
Well, I plugged in my scanner and it linked with the car as normal and will pull all the stored codes in the ECU. HOWEVER, when I try to erase the codes, It says it can no longer establish a link with the ECU. If I retry it, same story. I have heard of other who can’t even read codes so the fact I can read them but not clear them had flummoxed me. I’ve already checked the fuses under the rear seat and tried the 30 second negative lead to positive lead hard reset to no avail. Any advice on where to look next?
Old Dec 20, 2020 | 02:05 AM
Vauxi's Avatar
Try another code reader.
Old Dec 20, 2020 | 11:13 AM
Swagger XC's Avatar
Well, the scanner works well on my other vehicles so I assumed that wouldn’t be an issue. Are X308s really that picky with scanners?
Old Dec 20, 2020 | 12:02 PM
Vauxi's Avatar
Yes they are quite picky.
Old Dec 20, 2020 | 12:43 PM
Amphicar770's Avatar
If you have aftermarket radio, alarm, keyless start, etc. .... Any of those things can interfere with communications to ECU.
For a winter beater, I can't think of many worse choices than an x308.
Old Dec 23, 2020 | 07:04 AM
yeldogt's Avatar
Agreed
Old Dec 25, 2020 | 02:03 PM
Don B's Avatar
Hi Swagger,
P0138 is an oxygen sensor code. With your broken resonator, I'm surprised you don't also have lean codes such as P0171 and P0174.
Regarding your scanner behavior, check to be sure none of the pins in the cable connector have been bent. You checked the fuses in the right heelboard fuse box (fuse #10 is the relevant one which provides always-on battery power to the data link connector). Did you also check fuse #4 in the left heelboard fuse box? That's the ignition-switched power to the DLC.
Cheers,
Don
shirleycherry
Oct 25, 2018 05:33 AM
tomgee111
Jan 6, 2015 02:48 PM
Tarik
Nov 2, 2014 02:09 PM
Noxparadise
May 12, 2012 12:48 PM
urdrwho
Aug 9, 2011 12:36 PM
