2003 XJ8 Code P1121
Old Oct 7, 2013 | 08:28 PM
juliovega914's Avatar
Default 2003 XJ8 Code P1121
So I have an '03 XJ8, and it just threw a P1121 on me. Note its p1121 only (besides the p1111 or p1000 code it threw after I cleared codes.) No 16XX codes like you usually see.
About 7k miles ago I replaced the throttle body with a JayTan rebuilt one, so I am not in a rush to blame the TPS just yet. I checked all the fuses, none blown. Anything you guys can tell me?
Old Oct 7, 2013 | 10:09 PM
sparkenzap's Avatar
Well if it is not the TB, it would seam it is a bad wire or connector. Try looking at the connections for corrosion, then clean well with contact cleaner and reseat.
The JTIS diagnostics say:
Pedal position sensor to ECM sense
circuits 1 and 2 open circuit, short
circuit or high resistance
Sensor power supply fault
Sensor reference ground fault
Pedal position sensor failure
Good Luck
Old Oct 8, 2013 | 03:45 AM
Sean B's Avatar
P1121 isn't the TPS but the TPPS (throttle pedal position sensor) on the other side of the tb - this is more likely worn out if not replaced - if it keeps doing it, gradually getting shorter between restricted performance it'll need replacing.
Old Oct 8, 2013 | 02:34 PM
flay's Avatar
As long as none of the PS are available as spare, probably in these cases is more indicated to recommend a full refurb of the throttle body. I assume that they are changing both during the refurb process... or not? Anybody can guarantee this?
Is the car a X308 or X350?
Adam Lueb
Sep 28, 2015 02:54 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
jagfool
Sep 14, 2015 07:50 PM
corysansburn
Sep 10, 2015 06:15 AM
OkieTim
Sep 8, 2015 04:48 PM
