2003 xj8 vanden plas no 3rd
Old Jun 27, 2018 | 08:29 PM
up north's Avatar
Default 2003 xj8 vanden plas no 3rd
Hi folks got a question? my car shifts effortlessly when in D...... but when i use J gate shifter i have no 3rd gear goes from 4th into 2nd skips right buy 3rd.... could any one direct me on where to start looking? love this site lots of info i looked around but could find a similar thread thanks so much in advance
Old Jun 28, 2018 | 12:05 PM
avern1's Avatar
The J-Gate is a cable control that activates switches rather than selecting gears. Park, Reverse, Neutral and Drive each have a micro-switch that sends a signal to the Transmission Control Module indicating the shift position. When shifting the J-Gate over to the manual a rotary switch is engaged and tells the TCM the selector shift position.
If when driven in the D (drive) position and all gears operate normally when pulling from a stopped position the most likely problem is a defect in the rotary switch. The rotary switch won't affect your normal operations only the manual shifting operations.
Old Sep 8, 2018 | 02:41 PM
up north's Avatar
Thank you so much for advice sounds solid. Now is rotary switch inside where j gate is located? And would you know if it’s an expensive part? And for any one interested I just put new Michelin x touring tires on plus bilstein comfort ride shocks on a 2003 xj8 200.000 km on car. Now it drives like it should worth the investment
Old Sep 8, 2018 | 02:45 PM
up north's Avatar
Ok sorry just seen your post. Sorry now I understand thank again
Leif
Mar 27, 2018 07:43 AM
Jimmiego
Jul 19, 2017 06:50 PM
tbraunski
Jun 25, 2014 04:10 PM
96Jag68Triumph
May 2, 2014 12:30 AM
robertjag
Jan 19, 2013 09:10 PM
