2004 xj8 timing and tensioner rattle
Old Aug 21, 2014 | 03:33 PM
fmmsr45's Avatar
Default 2004 xj8 timing and tensioner rattle
does Jaguar have any kind of warranty for this, vehicle has only 70,000 miles but rattles when cold.
what steps should be taken now to avoid major trouble in the future? How dangerous is it to keep driving, does not make noise whan engine is warm. thanks, Mike
Old Aug 21, 2014 | 08:03 PM
RJ237's Avatar
Welcome to the forum Mike. I don't think there have been reports of tensioners or guides failing with your engine. Yet. But there is no recall. You need to remove the valve covers and inspect the chain system, or have a competent independent specialist look at it. I would avoid going to a dealer as they would likely tell you a new engine is called for.
When you have time, please visitthe new member area and introduce yourself:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Aug 22, 2014 | 07:29 AM
JimmyL's Avatar
Wouldn't a 2004 model be an X350 ? Different engine, 4.2, I believe, with a different valve train setup from the X308.
kelliott
May 31, 2022 05:26 PM
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
