2005 XJR supercharged wheels
Old Jul 13, 2019 | 02:31 PM
Nik Patel's Avatar
Default 2005 XJR supercharged wheels
Got a used supercharged 2005 XJR..absolutely beast of a ride.
Unfortunately I have just discovered my wheel is cracked on my rear drivers side and it tore up the tire. Need help finding a wheel, don’t need a tire as I already have a spare.
This is the wheel that I need. Have seen a few different ones that all look similar online and it’s got me really confused as to which is the correct one.
Also some punk tried to break in from the sunroof and ended up destroying my sunroof tracks, if someone knows where you can get one of those kits that would be much appreciated.
Old Jul 13, 2019 | 07:01 PM
Highhorse's Avatar
Hi Nik and welcome to the forums, first off your in the wrong forum, you want the X350 section... https://www.jaguarforums.com/forum/x...-x350-x358-28/
Plus, we would greatly appreciate it if you would introduce yourself and your Jag here (site requirement) it only takes two minutes.... https://www.jaguarforums.com/forum/n...-intro-must-5/
Also, if you could put your vehicle info (model, engine, etc..) and location (country, state, region) in your signature by using the Use CP in the top left task bar, that would greatly help those replying to your requests so you don't have to put it in each time.
But not to worry so much on those wheels, that is an easy fix for those rim repair places (you should have one local). Here's some other work from the guy who refurbished my Pentas here in Orlando, FL... GALLERY ...he did mine for $100 ea and they are still beautiful 5 yrs later.
They cost about 1/2 as much if not less than new/used rims and you'll have a source if you curb it in the future.
troy adams
41
Apr 22, 2024 09:53 PM
troy adams
Jan 31, 2019 10:10 AM
Wayne1357
Sep 25, 2018 02:31 AM
XJsc-guy
Jun 14, 2015 03:49 PM
09sleeper
Jul 6, 2014 10:20 PM
