3.2 sport battery not charging
Old Nov 14, 2017 | 10:02 AM
vwbusbits's Avatar
Default 3.2 sport battery not charging
Hi guys, it's been a while since owning my last jag but I have collected a 2002 xj8 3.2 sport today which had a charging issue.
the message centre reads battery not charging, the battery light is on and with the engine running the battery drops to 11.75v tested with a multimeter.
diagnostics gave an error code of P0560 system voltage malfunction.
probably obvious but thinking the alternator is gone? Any input more than welcomed.
cheers all and thanks in advance.
Old Nov 14, 2017 | 04:28 PM
Sean B's Avatar
Replace the battery before looking at the alternator.
Old Nov 14, 2017 | 04:33 PM
vwbusbits's Avatar
Thanks mate, I'll give that a try in the morning. It was parked up for a few weeks before I bought it today and this was new on start up according to the previous owner.
The battery shows 12.3v at rest, so will check it out thanks.
Old Nov 16, 2017 | 06:35 AM
vwbusbits's Avatar
Turns out to be the alternator. Followed a few previous threads on hete about it's removal, I went down the inner wheel arch lining out and fed it down through there, a bit fiddly but straight forward enough.
