98 Jag XJR running light prob
Old Jul 12, 2013 | 03:33 PM
kbrining1's Avatar
Default 98 Jag XJR running light prob
Side markers ,taillights would flicker and go out when touching the light switch. Took off bottom steering cover to find green wire from light switch was holding on with cover but I don't know wher it goes now. lights that were flickering are now off. It looked like it was connected to that little circuit board but I tried two places I thought it went and it just made the high beams stay on constant . (I just need to know where the green wire coming from the turn signal stem goes to on the other end) Thanks
Old Jul 12, 2013 | 07:22 PM
Welcome to the forum kbrining1,
I've moved your post from General Tech Help section to X308 section. Members here with the same model as you will be able to advise on the lighting issue.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jul 13, 2013 | 02:40 AM
It's a Green wire with no trace colour?
Here's the Lighting Stalk section of the wiring schematic for the US 98MY:
I can only see KG (Pink/Green) and YG (Yellow/Green) coming directly from the Lighting Stalk to the BPM (Body Processor Module).
convincor
Sep 3, 2015 08:03 PM
JakeJagg11
Sep 3, 2015 07:36 PM
Jandreu
Aug 29, 2015 07:31 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
