98 VDP
Old Apr 4, 2008 | 07:46 AM
JagtechOhio's Avatar
Default RE: 98 VDP
Hi dixter,
I'm not even going to ask about the screen name. That's in your hands.
Here's how to open your trunk:
Open the hood.
On the driver's side inner fender, up high, there are two black rectangular fuseboxes. The forward one is larger, and a thick black cable connect the two of them. On each end of the cable is a black rubber boot. Beneath each boot is a stud with a nut on it.On either stud iswhere we will connect battery positive. Hook a jumper wire, or your positive battery jumper cable, onto either stud.
Battery negative is anyplace you can attach your negative jumper wire or jumper cable that will give you a good ground. I use a small jumper wire to the ground stud on the chassis railbehind the left headlamps. Pick anyplace you like, so long as it is steel or aluminum and not painted. Jump from another battery (or a charger), positive to the fusebox stud, negative to your ground point. If you have a good ground connection, the interior lights will come on when you open the door. And the trunk release button will work.
The funniest part is that the relay for the trunk release motor is in...the trunk. If it fails, then you have to get physical.
The sunroof is another story: that's even a pain for a techster, never mind a di...well, you know.
Old Apr 4, 2008 | 12:08 PM
Markus's Avatar
Default RE: Boot entry
Others have had success with opening boot by removing rear license plate, poking long, thin screwdriver through the existing hole (rubber inside of hole pushes out of way readily), and tripping the latch arm. I personally have not had to dick around (!) with this method, but may be worth a try.
Sounds like your VDP has been resting for a prolonged time - battery terminals may be corroded, or battery itself is terminal...
________
1999 XJR
Old Apr 4, 2008 | 07:57 PM
FactoryJaguarTech's Avatar
Ohios method will work well. I use shock for the ground.
The sunroof is likely the arms have come off. Is a pain, but you will need to correct to fix leaky seal.
hkmcmast
Nov 29, 2015 06:56 AM
freddieg
Oct 6, 2015 11:23 AM
k-man
Oct 5, 2015 08:09 AM
freddieg
VENDOR 'For Sale' Classifieds
Sep 29, 2015 07:13 PM
Fletch44
Sep 28, 2015 02:21 PM
