98 xj8 ecm meltdown
Old Jul 5, 2011 | 06:47 PM
willy574's Avatar
Unhappy 98 xj8 ecm meltdown
On a 1998 xj8 4.0 NAS, has anyone had the ECM burn up where the EM15 plug comes in. The schmatic indicates this primarily controls the throttle motor. Wondering if this has happened to anyone before? And before I start tearing apart wiring harnesses trying to find a short, since the motor tested o.k.. Thanks for any input.
Old Jul 5, 2011 | 07:35 PM
test point's Avatar
Without looking at the schematic I would think that the circuit would be a fairly high current one because of the effort it takes to manually move the throttle motor. Before tearing apart the harness perhaps you should check the connector for corrosion/loose connections.
Haven't heard of that one before.
magmedia
Oct 8, 2015 03:28 PM
mat32essex
Oct 3, 2015 04:12 PM
3lvis
Oct 1, 2015 01:56 PM
donald ebanks
Sep 30, 2015 07:08 PM
