98 xj8 low oil pressure question
Old Feb 22, 2010 | 06:22 AM
test point's Avatar
I have the same problem occasionally only in cold weather, first start of the day. Am using the 5w30 full synthetic. Pressure comes up in 3 seconds like you say. Suspect it to be a sensitive oil pressure sensor rather than a real oil pressure problem.
Turn signal stalks have a history of broken wires.
Old Feb 22, 2010 | 06:56 AM
user 2029223's Avatar
Banned
Did the problem start the last time you changed oil filter? If so, change the filter with a quality brand as the problem may be related to a defective anti drain back valve in the filter itself.
Do let us know haw it sorts out. KBO mate.
Old Feb 22, 2010 | 07:54 AM
test point's Avatar
Only started when the night time temps stayed below freezing for a couple weeks in a row. Four months after last oil/filter change.
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
