98 xj8L turn signal and interior lights issue...
Old Feb 9, 2015 | 07:50 AM
Paulpop72's Avatar
Default 98 xj8L turn signal and interior lights issue...
When I turn on my right turn signal the lights on the radio go out. So do all other lights with the exception of the speedometer, RPM and Fuel. They slightly dim.
Everything is fine with the left signal.
Old Feb 9, 2015 | 09:05 AM
Jhartz's Avatar
Probably a broken solder joint in the multifunction switch. Easier to replace than fix unless you are really good with a soldering iron. Search multifunction switch; airbag; removing steering wheel and you should grab most of the threads that will walk you through the job.
Old Feb 10, 2015 | 11:43 AM
Paulpop72's Avatar
What about it being a short?
Old Feb 10, 2015 | 01:56 PM
Jhartz's Avatar
If the loosened wire is crossing other bare wires or solder points, maybe . . .. won't know until you take it apart, will you?
Old Feb 10, 2015 | 02:58 PM
Paulpop72's Avatar
Thanks for the help!
Old Apr 17, 2015 | 02:10 AM
Paulpop72's Avatar
Anyone know how many hours a mechanic will charge to change the multifunction switch??
Old Apr 20, 2015 | 05:01 PM
Sean B's Avatar
To someone who hasn't done it before it's a morning's work, experienced an hour.
Old Apr 21, 2015 | 02:45 PM
Paulpop72's Avatar
Thanks, Sean!! Do you know how much the part cost...ballpark?
Old Apr 21, 2015 | 09:27 PM
clyons's Avatar
Current e-bay listings: LNC6455aA | eBay
on-line jaguar supplier: SWITCHES for 1998 Jaguar XJ8
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
