98 XJR Spring assembly wrong??
Old Oct 28, 2012 | 07:38 PM
bsoth's Avatar
Default 98 XJR Spring assembly wrong??
Hi Everyone, I have an XJR and I removed everything on front spring assembly. The 2 sides had things in the different position. Im hoping someone can help me put the parts in the correct order.
front springs: There is a round flat plastic washer, another washer that has a cone on it and there is a rubber Grommet that clips into the spring. I would like to find out the correct order of the items to reassemble after being rebuilt. Both sides were different and I have no idea which way is correct.
Thanks in advance.
Bryan
Old Oct 28, 2012 | 08:13 PM
Bryan,
Does this help?
There can be more than one Spring Packer (item 2 - the flat washer) and not necessarily an equal number on both sides!
Old Oct 29, 2012 | 08:20 AM
bsoth's Avatar
This helps a bunch! Thanks
Forcedair1
Sep 8, 2025 01:57 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
metalmarty
Sep 11, 2015 07:05 AM
avern1
Sep 8, 2015 06:25 PM
Tar
Sep 6, 2015 11:24 AM
