98 xjr transmission fluid
Old Nov 9, 2021 | 05:53 AM
sbalint2003's Avatar
Default 98 xjr transmission fluid
My question is: would it be worth changing the fluid?
I bought a 1998 XJR a couple days ago and I have been considering changing the transmission fluid. It is my first automatic car. The previous owner claims it has been changed some 3 years ago. I have read that the transmisson in the XJR is pretty strong too. The car runs perfectly fine, no issues. Would it worth it? And if yes, what type of fluid is the most suited for the XJR?
Old Nov 9, 2021 | 08:23 AM
motorcarman's Avatar
Just use Mercedes 722.6 fluid recommendations.
https://en.wikipedia.org/wiki/Merced...c_transmission
Old Nov 9, 2021 | 06:53 PM
aquifer's Avatar
I would probably change it. Drop the pan off and replace the filter while you’re at it. You won’t get all the fluid out unless your torque converter is one that had a drain plug on it, so you might have to change the fluid 3-4 times and eventually you’ll be left with mostly new fluid in it.
XJRRRRR
Aug 4, 2021 06:25 AM
dan951
Mar 31, 2015 03:55 PM
97XJR-Flausa
May 29, 2014 04:39 PM
plums
Feb 26, 2013 11:11 PM
Fairlane500
Sep 18, 2010 10:38 PM
