99 X308 Instument Cluster Lighing
Old Dec 19, 2013 | 09:12 PM
mikebaker3's Avatar
Default 99 X308 Instument Cluster Lighing
How are the instruments lighted? I have a couple of dark areas as if bulbs are burned out.
Looking at Figure 10.2 Dimmer Controlled Lighting, in the XJ Series Sedan 1999 Electrical Guide the Instrument Pack does not indicate any bulbs (circle with an X inside). So what lights the gauges? Is it fiber optics? LEDs?
Last edited by mikebaker3; Dec 19, 2013 at 09:23 PM. Reason: removed excess spaces
Old Dec 19, 2013 | 10:05 PM
JaguarXJR02's Avatar
There are small bulbs. You have to take the cluster out to replace them, it's not a difficult job.
See this thread for more info:
https://www.jaguarforums.com/forum/x...not-lit-72902/
Old Dec 20, 2013 | 05:48 AM
Jaguar only supply replacement Bulb and Holder together so you may want to source aftermarket:
In this example from my XK8, the holder was badly scorched so I had to replace both Bulb and Holder.
If it hadn't been for this, I'd just have replaced the bulb.
Old Dec 28, 2013 | 05:32 PM
mikebaker3's Avatar
I followed the advice in this thread. I have attached some photos that show the details of changing the bulbs. I used 3.4 watt 194LL bulbs from Autozone. I had to use pliers to turn the bulb holders CCW to remove the holder. Bulb just presses in. Be careful not to crush the bulb holder with the pliers. I could not get enough grip to turn the holder with just my fingers.
Attached Thumbnails 99 X308 Instument Cluster Lighing-backside-instrument-cluster.jpg   99 X308 Instument Cluster Lighing-backside-wood-metal-intrument-facia.jpg   99 X308 Instument Cluster Lighing-release-clip-cluster-connector.jpg   99 X308 Instument Cluster Lighing-screw-behind-trip-meter-switches.jpg   99 X308 Instument Cluster Lighing-trip-meter-switch-mounting-connector.jpg
King Charles
Oct 16, 2015 01:25 AM
adam699
Oct 13, 2015 05:53 PM
waynepaulj
Oct 2, 2015 04:05 PM
mrplow58
Sep 30, 2015 08:56 AM
