99 XJ8 intermittent issue car only cranks but doesn't start
Old Dec 9, 2015 | 07:18 PM
steveyd1's Avatar
Default 99 XJ8 intermittent issue car only cranks but doesn't start
When car is cold its recently developed an issue of only cranking. After trying a few times it starts. Once warm it starts right up. Any ideas what may be happening.
Old Dec 9, 2015 | 09:47 PM
plums's Avatar
XJR you mean?
first suspect would be failing fuel pumps with the secondary already failed.
don't know what you mean by cold in relative terms.
Old Dec 9, 2015 | 10:57 PM
Cambo's Avatar
According to a previous post it's an XJ8 so i've updated the thread title.
SteveyD1 needs to add his car details to his profile, otherwise it will be very confusing for people...
Old Dec 9, 2015 | 11:09 PM
plums's Avatar
such as me
so ... intermittent operation of the only pump.
Old Dec 10, 2015 | 08:17 AM
convincor's Avatar
Wouldn't temp sender effect cold starts?
Old Dec 2, 2021 | 09:31 AM
John Arnold's Avatar
Default Change sensor AND connector!
I had similar issue that the car 04 XJR would not start. Turned over, spark, fuel pressure all good NO codes!! Many frustrating hours over a few days it finally came down to being coolant had seeped THROUGH the sensor into the connector coroding it ( no visable leaks).
New sensor and connector pigtail (NAPA sourced) changed. Started right up first turn.
ECU needs to know engine temp apparently as a given to do anything!!
Old Dec 2, 2021 | 10:51 AM
Parker 7's Avatar
There is a specific fuel injector relay on the V8
You can jumper the fuel pump relay and see if that helps
Bore wash condition of the cylinders?
swetnK
Dec 16, 2015 04:48 PM
FreshVinceOfBelAir
Dec 14, 2015 01:21 PM
Rob Edge
Dec 10, 2015 05:58 PM
x type diesel
Dec 9, 2015 05:40 PM
Steve M
UK & Eire
Dec 7, 2015 06:19 AM
