Throttle Body Question
Old Dec 1, 2021 | 10:24 PM
pcolapacker's Avatar
Default Throttle Body Question
Still chasing lean fuel trim codes. With no pressure on gas pedal, how much is throttle plate open? I was cleaning deposits off and noticed I can push plate down a few degrees to fully close it. Wondering if it is open at idle too much as only have high fuel trim numbers at idle.
Old Dec 2, 2021 | 01:36 AM
JagV8's Avatar
If too open it would raise revs but not trims.
If you have +ve trims at idle and they drop if you rev (about 2500) then you have an air leak.
Old Dec 2, 2021 | 08:59 AM
You're right, it's internal to air going through the MAF.
Fuel trim fine at anything but idle. Pulling 18 in Hg at idle so not a big leak. When removed intake manifold to replace thermostat tower, I didn't change manifold gaskets. Just ordered new gaskets and will see if that fixes. That may not be the issue because lean codes showed up a significant time after replaced thermostate tower.
Old Dec 2, 2021 | 02:58 PM
60Gunner's Avatar
Keep pumping that hot, oily air in there...
dannio636
Mar 23, 2023 10:07 PM
Tuifly767
Sep 29, 2021 10:20 AM
worzella
Aug 8, 2021 04:34 PM
nikki jordan
Dec 9, 2019 01:07 PM
jancar
Sep 16, 2014 01:08 PM
