99 xj8 vdp
Old Mar 11, 2013 | 08:51 PM
coastaljag98's Avatar
Default 99 xj8 vdp
Just purchased this car a few days ago and as long as it sits at idle it holds normal operating temperature. If I drive it the temperature will start rising and run hot. I'm suspecting a faulty thermostat, but wanted other opinions. ALso is there an overflow valve or tube on the coolant tank that when its running hot will open and leak water out so the tank doesn't explode? I have a drip under the car when it runs hot....after it returns to normal temperature the drip stops and if car is running in the garage it doesn't run hot or drip any water. Any ideas?
Old Mar 11, 2013 | 09:57 PM
dsnyder586's Avatar
Thermostat- most likely and cheapest place to start.
Overflow- allows for coolant to escape (which I imagine it needed when it got hot)
Old Mar 11, 2013 | 10:33 PM
That's what I'm gonna assume an start there tomorrow. Thanks.
Old Mar 11, 2013 | 10:36 PM
dsnyder586's Avatar
FYI- I just went through this last week with my XK8 rebuild. Fine at idle, then when I drove it a bit started to get hot, fans on high. Changed out the thermostat and she's been running perfect since.
Old Mar 12, 2013 | 01:09 AM
Tirefriar's Avatar
Definitely follow up on D's advice. In addition, I strongly recommend installing the Real Gauge. Basically the temperature gauge in the X308s works more or less like an idiot light, i.e. it will either say you are running ok or wham, boom, crack - you have overheated. By the time it goes to hot it could be too late.
Contact Stever at <steve.klonsky@comcast.net>. He makes and sells Real Gauge that turns the temperature indicator into a "live" gauge. Good luck.
Old Mar 12, 2013 | 09:01 AM
Thanks guys
Old Mar 14, 2013 | 12:52 PM
ixj8it's Avatar
If I was keeping mine, I would totally get the realgauge.
magmedia
Oct 8, 2015 03:28 PM
freddieg
Oct 6, 2015 11:23 AM
donald ebanks
Sep 30, 2015 07:08 PM
freddieg
VENDOR 'For Sale' Classifieds
Sep 29, 2015 07:13 PM
Fletch44
Sep 28, 2015 02:21 PM
