99 xjr dash lights
Old Apr 5, 2013 | 07:09 PM
jaguar jon02's Avatar
Default 99 xjr dash lights
any brains out there know what happened to my kitty. let battery run down and now want turn over and all dash lights flash for 10-15 sec after i remove key was running good.
Old Apr 6, 2013 | 09:50 AM
SuperSport's Avatar
Battery still needs a charge? If you already did that, maybe it didn't take the charge? Sometimes, when the battery gets too low, chargers don't like to start charging. I've placed jumpers from another battery on them to get the charger going, then remove the jumpers when the charger takes hold.
Old Apr 6, 2013 | 03:08 PM
RJ237's Avatar
It would probably be worth the effort to take the battery to Autozone, or other parts supplier and have it tested.
Old Apr 7, 2013 | 02:23 PM
put the battery from my m/b diesel(1000 cca) in it. same thing. want even click
Old Apr 7, 2013 | 02:34 PM
JimmyL's Avatar
Have you checked the connection at the false bulkhead ? This is a common problem. It's under the hood, right side, where the power goes through the part under the right side plastic cover and comes out into the engine bay. Not a good explanation, but plenty on this forum if you search on false bulkhead connection. There is also a ground under the right side that goes from the bell housing to the frame that can be a problem. Also, the ground strap at the battery itself can give problems. Just throwing out some suggestions. I had a problem Friday with my Jag. It lost all power. I called the wife to bring the jumper cables, and the second I moved the positive terminal I got a slight spark and voila, power back. Too much dielectric grease I guess.
Old Apr 10, 2013 | 06:41 PM
something is keeping the small wire on the solenoid from getting power. can jump across and turns over good
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
XJsc-guy
Sep 25, 2015 11:09 AM
