99 XJR Drivers Lower Control Arm
Old Mar 24, 2020 | 09:15 PM
rts1021's Avatar
Default 99 XJR Drivers Lower Control Arm
I have a bad front lower ball joint on the drivers side of 99 XJR. I'm having a hard time finding the entire control arm and have read horror stories about trying to just replacing the ball joint. I have found a pair of front lower control arms for a 2002 XJR does anyone know if these will fit my 99? The listing states they only fits 2000-2002.
Old Mar 25, 2020 | 12:57 AM
AZjag1999's Avatar
They should be the same. I just did a front suspension rebuild and decided to replace the ball joints and bushings themselves as opposed to the whole control arm. I had a machine shop replace the balljoints and bushings for $35 a piece. So if you go this route, all you'd have to do is take out the control arm, and find a machine shop that can do it, and around $150 later you can have a new ball joint and 2 new bushings installed.
Old Mar 25, 2020 | 06:08 AM
Carnival Kid's Avatar
The front-lower control arms have a different part number for 1999 and 2002 model years (MNC1311AE and MNC1311AF) so I would assume they are different.
And as the earlier type is now discontinued, and priced at close to $500 if they were available, I think AZjags advice would be the way to go.
Old Mar 25, 2020 | 08:35 PM
rts1021's Avatar
Thanks fellas. Looks like I'll be looking for someone to press some joints and bushings for me.
Old Mar 26, 2020 | 09:21 AM
Mvirgil's Avatar
I think the Early to late difference lower arms changes related to the bushings, front and rear bushing have gone through multiple updates since 1998: See TSB 204-S499A.
Old Mar 26, 2020 | 09:35 AM
rts1021's Avatar
So it looks like the 2002 control arms would work if Im reading everything correctly!
troy adams
May 21, 2016 07:22 PM
beady
Jan 14, 2016 06:43 AM
Noxparadise
Jul 15, 2014 08:54 AM
Jag69
Feb 19, 2010 05:51 PM
