99 xjr secondary tensioner problems
Old Jul 13, 2011 | 08:33 PM
ROC's Avatar
ROC
Default 99 xjr secondary tensioner problems
If any one could help i`d be very thankful. Any I didnt know what was wrong with my car, so I got my neighbor who is a toyota mechanic to look at it. He had me order some parts and put then in and that was not it. Then I called samuals jag in Brighton MA USA told him what was going on and he knew right over the phone what it was. THE CAM TENSIONERS sure enough they wre craked. So my buddy put them in and the car ran smoother but it still has that rattling noise and another which sounds like the supercharger which we will deal with later. Right now my question is Is the cam chain supposed to have slack in it ? Right now I have the driver side valve cover off cause I wanted to see what he did.
Old Jul 14, 2011 | 04:13 AM
Sean B's Avatar
hmm, it could be the primary tensioners and guides that could do with replacing if you have slack in the chains. If you can get a look down behind the timing cover and check them out.
The supercharger, to confirm if it's rattling, take the belt off and run the engine, or use a long screwdriver and hold it to your ear, or engineers stethoscope and locate the noise while the engine is running. If it's noisey, it'll need bearings and coupler, a rebuild.
Old Jul 14, 2011 | 09:52 AM
ROC's Avatar
ROC
Ok ! Sean thanx for replying, So my email message from u said I have to read my reply before I can get another Is that true? Anyway Im going to get a long handle mirror so i can look behind thetiming chain cover. But, is the uper cam chain supposed to be loose????
Old Jul 14, 2011 | 11:03 AM
JimmyL's Avatar
The upper chain is not supposed to be loose. When I replaced my secondary (upper) chain tensioners, the chain was pretty tight. No slack at all. The tensioners should take up any slack. If they don't, either the tensioner is not working correctly or the chain is stretched. There is a little pin that has to be pulled on the new tensioners after they are put in place to let them "spring out".
Old Jul 14, 2011 | 11:34 AM
ROC's Avatar
ROC
Jimmy,,,,,Thanx for the comeback Ive been on this keyboard & mouse all morning Im puting on my work clothes and going under the hood with a mirror. I know the driver side chain is very loose ill go check on the pin.
Old Jul 14, 2011 | 01:51 PM
ROC's Avatar
ROC
I turned the engine a little and found that the tensioner is working, great! But i looked at what looks like looks to be the lower guide and its in 2 pcs, is that supposed to be?
Old Jul 14, 2011 | 01:55 PM
ROC's Avatar
ROC
The upper tensioner is fine. But now i looked at the lower guide and its in 2 pcs is that ok?
Old Jul 14, 2011 | 05:51 PM
sparkenzap's Avatar
Well, there are 4 lower guides. Laft and right bank, and slack and tension side. So, NO, if any one of the 4 is broken in two, it is not particularly fine.
Forcedair1
Sep 8, 2025 01:57 PM
Jpav27
Jul 31, 2022 06:43 AM
XJsc-guy
Sep 25, 2015 11:09 AM
laserguy
Sep 3, 2015 02:02 PM
