ABS mod repair
Old Aug 23, 2015 | 06:47 PM
TreVoRTasmin's Avatar
Default ABS mod repair
So I finally got the dreaded failure codes today on my XJR (have had them on the xk8 since I got it and have not done a perm. fix myself re-soldering it for a long term fix. Works for a couple months and then its back). Where have others who aren't electrically sparky sent theirs and were they happy with the fix? Thinking about the place on ebay in mass as it is closest so I should have 'em back sooner.
Old Aug 23, 2015 | 07:56 PM
avern1's Avatar
Give Darryl Turner a call at 858-649-9090. He does very good work on module repairs. I don't know particulars for ABS Module but he has done a couple of modules for me. He is retired navy electronics tech and is in San Diego California
Old Aug 24, 2015 | 06:03 AM
RJ237's Avatar
ASI in Tenn. has a good reputation. Most repair services just solder the pins, but ASI also tests the modules to see if there are other problems with the circuits.
You should be able to get a permanent fix yourself. The biggest problem is not getting a good joint. You need to scrape the insulation from around the post first, and use enough heat get the solder to flow, then use epoxy to reseal. I even use flux and silver solder, but than it's necessary to remove the excess flux with q tips and water.
Old Aug 24, 2015 | 10:22 PM
VR6Guru's Avatar
I don't have any personal experience with this company but I did notice this today while browsing their site.
Jaguar Parts - Jaguar ABS Module Repair Service
Old Aug 25, 2015 | 10:21 AM
Sean B's Avatar
Getting it off and out is the hardest part of the whole damn job, the cutting open is easy, the soldering is easy and bonding it shut is easy. Takes half an hour to do, plenty of non tech guys have carried out this fix and saved a few bob($$$) not to mention the boost in confidence you can carry out your very own repairs. Just do it
Old Aug 28, 2015 | 12:33 PM
jagmanv8's Avatar
I had this problem too on my XJ8...intermittent ABS on and then permanently on....I researched the self repair and tried it...pain in the butt.....in the end I got a guaranteed reconditioned module off ebay, easy fit,not that much money and no problem since, and this was months ago.
ericjansen
Dec 19, 2021 12:20 AM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
John Fox
Sep 19, 2015 07:56 PM
mrobinson
Sep 18, 2015 07:20 AM
Doovoe
Sep 8, 2015 05:42 PM
