abs warning and trac/and asc failure light on
Old Aug 13, 2007 | 09:09 AM
badmojo's Avatar
Default RE: abs warning and trac/and asc failure light on
When this has happened to me it usually goes away when I drive for a little bit and then restart the car.
Old Aug 13, 2007 | 05:43 PM
jag_genius's Avatar
9 times out of ten you need a ABS MODULE ..$1800.00 or get it rebuilt... or i can rebuild it... if you scan for codes you'll find C1095
Old Aug 15, 2007 | 12:50 PM
ken@britishparts.com's Avatar
We go through a lot of rebuilt ABS modules. I'm not so good at the trouble shooting on these, but can tell you the common part.
Old Aug 17, 2007 | 05:23 PM
jag_genius's Avatar
then it seems you have a wheel speed sensor link open circuit..the car test the continuity of them during start up..
Old Aug 21, 2007 | 01:10 PM
Jeez badal.......sorry to hear about your pain bud. Sounds like you dropped a bundle on the car already? You gonna stick with it?
Jim
Old Aug 22, 2007 | 07:34 PM
jag_genius's Avatar
ya for sum reason the abs sensor are way over priced like $300 .. and they get seized in as well..
Old Apr 30, 2008 | 04:57 AM
FactoryJaguarTech's Avatar
The worst that would happen is the wheels will lock up during panic braking. Also when driving in the wet you would have no stability control.
Orca, if yours came on like that, probably your module going bad. My 2001 does the same thing once in awhile.
Old Sep 25, 2008 | 10:38 PM
skanoski's Avatar
I had this happen - I turned the traction control off while the engine was running, and it went away with the next restart. It came up another time, I did the same thing and it went away again - hasn't been back since. Worth a shot if you just want the annoying warning lights off.
