Ac drain lines on 99 xj8
Old Sep 14, 2016 | 07:50 PM
coastaljag98's Avatar
Default Ac drain lines on 99 xj8
Does anyone know where the Ac drain lines come out under the car? Mine are clogged I have water in my floor and I can't see where to find them? Pictures or any help would be great!
Old Sep 15, 2016 | 12:22 PM
avern1's Avatar
The drains are on the left and right sides of the center console. Attached is an excerpt from the tech manual.
File Type: docx
Old Sep 15, 2016 | 12:34 PM
I can't read that format. Do you have a picture of what they look like anyone ?
Old Sep 15, 2016 | 01:02 PM
I've been under this car so many times today and don't see any tube anywhere under middle of the car where console Is. Ughhh!
Old Sep 15, 2016 | 01:10 PM
Samilcar's Avatar
Looks like the tubes exit out into the transmission hump.
Old Sep 15, 2016 | 01:32 PM
avern1's Avatar
Samilcar thanks for opening the document. Another drain thaat plugs up and causes flooding is the windscreen/facia drain on the right hand corner of the facia. If it is the passenger side only then it is probably the culprit. The drain can be accessed after removing the facia or also can be found exiting the bottom of the car just forward of the front door seam. You have to rub around until you find a little flexible nub sticking out.
Vern
Old Sep 15, 2016 | 06:13 PM
Found my issue. Pulled up front carpet and saw my drain line had come loose from the evaporator. Can we say shiiiiiiit! Now I have to pull the seat and pull up the carpet since thst nice spongy thing under it is full of water. 😥😥😥
Jag Brent
Sep 25, 2023 11:02 AM
Helen Serrano
Sep 15, 2016 05:17 AM
car5car
Sep 14, 2016 04:02 PM
shemp
Sep 14, 2016 01:25 PM
99jagVDP
Sep 11, 2016 07:34 PM
