accelerator cable
Old May 13, 2008 | 12:16 PM
wdmoreton's Avatar
Default accelerator cable
Hi guys, an easy one for you :
1999 XJR 75k mls.
I have some play in my accelerator pedal, maybe half an inch or less, which I am assuming is due to the cable. So is tightening the cable something I can do myself ? If its easy can you talk me through it ?
Any comments appreciated.
Old May 13, 2008 | 12:58 PM
FactoryJaguarTech's Avatar
Default RE: accelerator cable
Should not need adjusting.
If you choose, remove the two 20 torx bolts securing cable to throttle body. Pull throttle plate open where cable attatches and remove cable from throttle body. Rotate black mounting plate to adjust cable and resecure everything in reverse.
I forget which way to go but it is threaded so should be obvious once you are there.
Old May 13, 2008 | 02:00 PM
wdmoreton's Avatar
Thanks FJT.
If it shouldn't need adjusting I'll probably leave it alone. I'll have a closer look at the weekend.
Old May 13, 2008 | 05:29 PM
My 2001 has a little play in it also....just went out and checked. I think that play is for the mechanical guard thing.
Old May 13, 2008 | 06:32 PM
wdmoreton's Avatar
Its really irritating. The rest of the car is so "tight" and well put together, that little bit of play when I put my foot on the pedal spoils the whole Jaguar feeling.
I think I need a psychiatrist rather than a Factory Tech [&:]
jimforrest (uk)
Feb 28, 2019 06:42 PM
adam699
Oct 13, 2015 05:53 PM
tomkilner
Oct 9, 2015 07:10 AM
10 XF Premium
Oct 2, 2015 09:22 PM
