Adding VDP tables & seatbacks to your XJ8 - in 30 mins or less.
Old Mar 25, 2014 | 05:37 PM
Stu 1986's Avatar
I have these tables standard in my car, as it is a full Daimler SVO (Special Vehicle Operations) interior, similar to the VDP interior, but everything (and I mean everything) is real Ivory Connolly leather. There are 2 things to watch out with them:
1) Passengers or people who try to operate them will get it wrong first time generally, which puts stress on the little screws. Which leads to:
2) The little screws holding the tables on can work loose and cause the table to rattle with the car's motion.
Old Mar 25, 2014 | 08:46 PM
Vector's Avatar
You should give your passengers the same instructions I do:
Rules for my car:
1. Get in.
2. Sit down.
3. Hold on.
4. Shut up
5. Don't try to operate any passenger accessible features of the car that you don't fully understand.
(#5 recently added, thanks.)
Vector
Old Mar 25, 2014 | 09:12 PM
Zorasmiles's Avatar
Originally Posted by Probesport
Chris,
Did you ever get around to splicing wires? I havent hooked mine up yet
Ken,
I haven't gotten around to the seat wiring, let alone installing the trays. Working on getting her running and that leaves no time for the fun mods. Like others I've searched the net only to see "I've done this..." but no pictures or wire-to-wire diagrams.
Old Mar 27, 2014 | 09:54 AM
Probesport's Avatar
Yeah I hear that, it's low on my list to have rear passengers messing with seat settings
Old Apr 22, 2015 | 11:10 PM
Forcedair1's Avatar
Rules for my car:
1. Get in.
2. Sit down.
3. Hold on.
4. Shut up
Vector
Add #6: If you MUST have Grey Poupon, well then ask for it...
Cheers,
Old May 14, 2015 | 10:53 PM
Pilotman11's Avatar
Thanks for this post! After reading it; this will definitely be a future project for my Jag!
Old May 18, 2015 | 11:53 PM
GGabriel's Avatar
Default Great post
Way to go guys. The rear trays finish it off beautifully. I think ever XJ should have them. Burl walnut beats leather any day.
Old Jun 13, 2019 | 08:27 PM
  #28
2000c43's Avatar
XJ8 SWB non-VDP with AGD / Oatmeal Interior
Great write up. Thank you. Super easy to do following the instructions you provided. I had no trouble doing it at all. Didn't have time to tackle the seat switch wiring but I plan to do so and post back when done.
Old Jun 15, 2019 | 02:25 AM
Stu 1986's Avatar
I’ve actually got a complete kit available to do this, includes necessary seat backs, tables, screws & switches for moving the front seat. The leather is oatmeal AGD and the wood is burr walnut. Removed from a 1998 Daimler V8.
Collection only in the UK due to size and weight, but available if anyone in the UK wants to do this.
Old Jun 15, 2019 | 09:13 AM
  #30
XJDanny's Avatar
I would love to do this to my XJR. I looked on eBay but no one if offering them in black. If anyone has them in black, please let me know. I’ll continue to watch eBay and hope they pop up.
Old Sep 2, 2019 | 08:34 PM
  #31
Blown Income's Avatar
If this was only state side, same colors in my 98’ XJR and would love to add the trays.
Old Mar 25, 2020 | 04:02 AM
  #32
Anders2jags's Avatar
anyone know if this is possible to modify a series 3 xj6 with these tables?
the width dimensions are probably wider on my seats, and there will be no screw holes,
but could some wood block be mounted on the seat back to hold the screws and table weight?
thanks if anyone has any bright ideas
Best
Old Sep 18, 2020 | 12:25 PM
  #33
aquifer's Avatar
I realize I'm resurrecting an old thread, but it's directly related to what I'm doing with my '98 XJR. The seat backs I got off ebay don't fit correctly to the seats in my car. I have two questions:
1. Were all of the X308 picnic tray seatbacks the same from year to year?
2. Were the 98 XJR seatbacks different than later years?
The problem is that the foam on my seat back seems to be too bulky. The "tray" seatbacks do not fit up correctly. It looks like the holes would line up if the foam wasn't so thick that I can't push the new seatback in place. Supposedly the ebay seat backs and trays were from an 02 VDP I think. I know the seats themselves are different across the various models, but I didn't think the seat BACKS were different. Any thoughts? Thank you!
Old Sep 18, 2020 | 12:40 PM
  #34
xalty's Avatar
All 94-03 picnic tray seatbacks mount in the same way, 308s have different passenger side controls and that's about it. If you want to put the seatback in you have to unscrew the bracket for the standard mounting clips, rip the cardboard lining out and ditching the foam out also helps a lot. Take a boxcutter and cut the extra leather until you can clearly see the upper VDP table (obviously 100% irreversible) screw holes and you should be ready to go. XJR seats are slightly different from normal ones but I'm pretty sure they use the same back section.
Old Sep 18, 2020 | 01:10 PM
  #35
aquifer's Avatar
Ok that helps. That’s exactly what it looks like I need to do, but I wanted a second opinion before I do any cutting. Thanks
Old May 29, 2025 | 10:11 AM
  #36
larrygee's Avatar
Move the seat all the way forward
Remove two screws at the bottom of the seat back
Pull the bottom outward slightly to release the.
I know this is an old thread, but I thought this might be helpful.
There are also two metal clips on each of the side bolster of the old seat back that need to be disengaged (no screws).
They are forward of the button screws.
Be gentle. The metal clips simply hook over each other, and you need to push the seat back forward and then pull the side of the seat back to clear the other clip.
I know this because I just did this job today.
Old May 30, 2025 | 04:26 AM
  #37
Vector's Avatar
Default Spare tray tables
I have a spare set of tray tables available, listed in the for sale section. If anyone needs them.
Vector
Old May 30, 2025 | 05:14 AM
  #38
larrygee's Avatar
Vector
Don’t see them…. Private? Vendor?
Old May 31, 2025 | 05:33 AM
  #39
Vector's Avatar
Not private but I listed them several months ago they are way down in the listings just shoot me a p.m..
Vector
Segfault
Mar 31, 2019 08:59 AM
RaceDiagnostics
Oct 28, 2018 12:08 PM
Corbin
Feb 23, 2017 03:40 PM
RaceDiagnostics
Jul 30, 2016 04:55 PM
Cambo
Dec 10, 2011 10:21 AM
