air cleaner tube question
Subscribe
May 4, 2017 | 05:38 PM
Hi
Just purchased a 2002 XJ8, I bought it as a bit of a project as my 1998 xj8 was wrote off a few years ago.
My new used XJ8 was found to have a rag shoved into a hole at the bend of the air cleaner intake tube adjacent to the firewall ( it looks like there may have been a plastic plug about 1" in Diameter from the factory).
I found a small plastic plug with which I filled the hole and glued it in there, and it did of course bring the idle down a bit, but does anyone know what was suppose to be in there? Was it a plug or am I missing a hose of some sorts.
Cheers,
Kejar7
Reply 0
May 4, 2017 | 05:44 PM
Are you referring to the straight piece that "T's" off from the curved section? If so, that was put in to supress the noise of the intake. Doesn't really have a purpose for anything else. I believe that some models, supercharge I think don't even have that as part of the air intake. Someone with an R model might be able to confirm this.
Reply 0
May 4, 2017 | 05:47 PM
Hi Yes that would be the area in question. I guess I will just leave my plug glued in there. LOL
Reply 0
If you look in this picture, where the bend is going to Throttle Body, that's where the "silencer" piece would be, but I'm pretty sure that the R models didn't have it.
Reply 0
May 4, 2017 | 05:50 PM
Just looking at the diagram and that area is at the opposite end I am asking about. The end I am asking about is adjacent to the firewall.
Reply 0
May 4, 2017 | 05:56 PM
I wasn't referring to where #2 is, I meant the part behind that where it makes a 90 degree turn to the throttle body ( #1 ) , the firewall is on the RH side of the pic, is this correct?
Reply 0
May 4, 2017 | 06:03 PM
Quote: I wasn't referring to where #2 is, I meant the part behind that where it makes a 90 degree turn to the throttle body ( #1 ) , the firewall is on the RH side of the pic, is this correct?
Google is your friend ..
Reply 1
May 4, 2017 | 06:04 PM
Hi
Yup I misread that. Yes that's the area in question.
Reply 0
May 4, 2017 | 06:36 PM
Yeah in the pic that ericjansen posted, that straight piece coming off, its a silencer, doesn't add or take away any performance, unless its cracked and starts a vacuum leak, which I've seen happen quite often in the past. Thanks for posting the picture ericjansen.
Reply 0
Subscribe
Currently Active Users (1)
