Air conditioning not working 2002 xj
Old Jul 14, 2015 | 12:44 PM
drnick66's Avatar
Default Air conditioning not working 2002 xj
I have recently bought a 2002 sport. The air con didn't work, so I had it re-gassed. All was good, for a couple of weeks, then over night it stopped working. I've checked the fuse, and the low pressure, both are good. Has anyone any suggestions?
Old Jul 14, 2015 | 01:16 PM
drnick66's Avatar
That should've said fuses
Old Jul 14, 2015 | 02:47 PM
cybercg's Avatar
Most likely, the system lost/leaked the charge overnight. Did you charge the system or did a shop? The AC system will not run if the charge pressure is too low to protect the compressor.
Old Jul 14, 2015 | 04:33 PM
drnick66's Avatar
The shop regassed the system, and the low pressure is bang on 55psi, perfect. I assume that a leak in the high pressure side would cause the low pressure side to fall a little.
I have read about the expansion valve filter blocking, but can't find how to check this? I don't think there is moisture in the system, as it was perfect for a couple of weeks after degassing.
Old Jul 14, 2015 | 06:29 PM
Lear45's Avatar
You need to know what the high side is and the low to properly diagnose the system.
Is the compressor engaging?
The expansion valve is not easy to access. You don't want to change it unless it is bad.
Old Jul 15, 2015 | 02:48 AM
drnick66's Avatar
Thanks lear45. I'll get on that tomorrow.
montypeek
Sep 6, 2015 04:57 PM
johanasu
Sep 3, 2015 12:39 PM
martybmw
Aug 31, 2015 10:15 PM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
