Air conditioning out.
Old Jun 18, 2025 | 01:26 PM
Ritchie2003's Avatar
Default Air conditioning out.
My ac started blowing hot air on my 2003 XJR. (X308). The fuse (#8) was blown and new fuses blow when replaced. Checked ac refrigerant and it's full. Mechanic thinks it's the compressor clutch coil. They only sell the whole compressor/clutch/coil combo together unfortunately I think. My first thought was also the compressor coil but after looking at old threads on here some have mentioned pulley malfunction or belt tension problems. A week ago I had a mechanic replace a bad pulley and belt for my supercharger as it stopped working. I'm wondering if he removed and reinstalled the belt driving ac to get to all that. Maybe it's just a coincidence the ac went out a week after that work or maybe not. Any thoughts would be appreciated. Thanks.
Old Jun 18, 2025 | 01:57 PM
motorcarman's Avatar
The X308/X100 uses a DENSO 10PA17C A/C compressor.
Search yielded results.
https://www.ebay.com/itm/A-C-Compres...09bdbe75c20ed3
Old Jun 18, 2025 | 01:58 PM
scottjh9's Avatar
Blowing fuses is mostly a shorted component or component drawing excessive amps. I would look for maybe a pinched wire in the area of previous work. You can also unplug the compressor if possible and then activate a/c to see if fuse blows. Yes would mean a pinch wire i would think. If not then coil/clutch is bad or even compressor locked or very close
Old Jun 18, 2025 | 06:44 PM
Addicted2boost's Avatar
Make sure both fans are running also.
Old Jun 18, 2025 | 07:00 PM
scottjh9's Avatar
to get to the compressor plug you take off the left front wheel and wheel liner.....then you can access the plug....on the R models the subframe is real close to the compressor...the liner is straight forward to remove...a few plastic pop clips and a few bolts
Old Jun 19, 2025 | 09:17 AM
Thank you all for those suggestions. Going to check each one by one. I'll let you know what I find!
LKEtype
E type ( XK-E )
Jan 12, 2023 07:39 AM
Reklaw1973
Oct 3, 2019 10:28 AM
muttony
Jul 15, 2019 07:16 AM
NtAFord
Aug 20, 2014 10:23 AM
TomSaintJames
Apr 16, 2014 05:40 PM
