Alarm going off every hour for 30 sec
Old Jun 29, 2022 | 01:20 PM
ErZam's Avatar
Default Alarm going off every hour for 30 sec
I had new keys made by a specialist in Milton Keynes, no remote activators were delivered. now after a month , the alarm goes off every hour for about 30 seconds. how can i deactivate?
Old Jun 30, 2022 | 01:14 PM
RandyS's Avatar
This may not be the answer you need, however it seems obvious that if you don't want the
alarm to sound, don't activate it in the first place.
Old Jun 30, 2022 | 01:44 PM
asdf's Avatar
I had a similar issue on 2 occasions. First was the my remote was low on battery and went haywire activating the alarm every once in a while. Replaced the batteries to fix it. The second was that a door switch was broken, resulting in a door open signal being sent to the computers and the alarm going off. To test of the second one, put the key in the ignition and close all the doors. A door open signal will appear in the dash lights if a door switch is broken. In my case, I was a bit broke at the time and just snipped the wires instead of finding a replacement switch. It could also be neither of these issues.
I may be mistaken but I believe that if you just push down the door locks instead of using the key to lock the car, it won't turn on the alarm system and therefore it can't go off. It's not exactly ideal but it's what I had to work with to avoid my neighbors killing me the various times my alarm kept going off.
Old Jul 1, 2022 | 05:25 AM
ErZam's Avatar
I didnt activate it in the first place , it was done by the garage but i am now in Belgium with the car and dont know how to diactivate other then just leaving the car unlocked
Old Jul 1, 2022 | 09:09 AM
RandyS's Avatar
OK. To lock the car without activating the alarm, just push the individual door locks down with your fingers.
Old Jul 1, 2022 | 09:25 AM
motorcarman's Avatar
There is a feature in the modules (SLCM) that include a 'LAST ALARM ACTIVATION' lookup.
WDS, IDS, SDD will be able to find the info in the setup and configuration area.
Jan van Tongeren
Oct 18, 2019 11:35 PM
PinnacleWax
Detailing / Car care
Jul 24, 2015 11:35 AM
Schoe
Sep 22, 2014 03:36 PM
bigdollar
Sep 27, 2011 11:08 AM
snooktarpon
Jan 13, 2009 07:47 AM
