Leather Seat Repair Help
Old Mar 28, 2022 | 06:39 PM
ncanales33's Avatar
Default Leather Seat Repair Help
I have read some of the forums, seems like everyone has a different opinion. I need help to find the best product for dry seats, and to repair the following. If it helps, I am located in the U.S.
Old Mar 29, 2022 | 04:06 AM
ericjansen's Avatar
From experience, start cleaning with a very good leather cleaner, then clean again, then again .... that really is the trick I learned over the years, doing a dozen of Jaguars.
After that, I can recommend Furniture Clinic has a nice range of good quality products to further repair and dye in the correct color.
Old Mar 29, 2022 | 05:37 AM
eliotb's Avatar
another source of good cleaning and restoration products is Leatherique. I've used their products for the last 22 years of Jag ownership, though I've not done any dyeing as I haven't needed to. It's good stuff. There's a gent, Robert Laughton (sp?),who may be on this list but I believe is also on Jag-Lovers.org, who is a distributor. I think the website is Home Page | Leatherique Restoration Products
Old Mar 29, 2022 | 10:32 AM
ncanales33's Avatar
Hello, I did look at the furniture clinic. I also looked at leatherique. I noticed that there are two types of oatmeal. My trim code is AGD, not sure what dye to choose.
Old Mar 29, 2022 | 12:49 PM
RJ237's Avatar
Leatherique will match a 1" square that you can remove from under the seat.
Old Mar 30, 2022 | 05:03 AM
c16rkc's Avatar
I can recommend using a degreaser to clean; such as Meguiars super degreaser. Water it down 50:50 and spray it on using a fresh spray botttle, then work it in with a shoe polish brush. This gets all the contaminants off, and all the oils out.
The let it dry thoroughly before you paint.
I would also sand it down before you paint, so that you do not get all the cracks showing afterwards. A filler might be needed if you have any heavily worn patches.
I would then dab the dye on using a small sponge in thin layers - 5 or 6 layers, maybe 10, until the covering looks even.
Old Jun 29, 2022 | 12:56 PM
RandyS's Avatar
Well Chris, your detailed instructions almost make me want to drag my old seat leather out of storage and give it another shot.
I had purchased the Leatherique (complete 4 step system) but did not acquire the desired results. It may be that what my leathers
needed was a miracle, not an impatient engineer. I had cracks that I filled but they never seemed to quite blend in right. In the end
I just purchased new leather and had it installed by professionals.
Old Jun 29, 2022 | 04:09 PM
markdpeter's Avatar
I called by a well known Connolly leather specialist in the North of England to ask him for a price on renovating the interior of one of my cars. 35 years of experience was great to listen to. He was showing me the interior of a Daimler he was repairing that had been painted with two pack body paint! I couldn't believe it but then then showed me repairs he had done on a $1.25m Ferrari Enzo which someone painted with exterior paint.... I was speechless.
So, follow Chris's guidance - you can see from his ownership thread how great his results were - and don't just paint your leather with a can of gloss
Old Jun 30, 2022 | 05:19 AM
RandyS's Avatar
After looking into the particulars of this subject, I discovered I had attacked the task equipped with
neither the required time or patience required for the job to be done in a proper manner. (something
Americans in general have in short supply) I have decided to try my hand at renovating the leather
in proper fashion. I certainly appreciate the attention to detail in the comments which indicate how
the job should be approached for recognizable success. Thank you.
Old Jul 1, 2022 | 01:25 PM
mayhem's Avatar
Limited to one experience with a 1980 BMW 733i, but I used Honey Leather cleaner and conditioner and I was extremely pleased with the results. Worth a look and compare to other products as you see fit.
Old Jul 1, 2022 | 05:59 PM
RandyS's Avatar
Yes sir, I have used quite a few different ones over the years. Some were better than others and some
were worse than nothing. The Leatherique system has acquired some glowing reviews and I am trying
to follow the guidance a little better this time around. It seems that there is a real tried and true method
of restoring cracked skins that requires more patience than is in my normal purview.
AllBlackFtype
Nov 25, 2020 01:22 PM
sanchez
May 15, 2019 07:22 PM
Billhenderson
Apr 27, 2015 06:51 AM
mtotrainer
May 29, 2008 08:59 AM
JagJoel
Jan 2, 2008 11:56 AM
