Alternate tire size - 03 XJR
Old Mar 27, 2010 | 04:45 PM
Fairlane500's Avatar
Post Alternate tire size - 03 XJR
I will be replacing my Michelin Pilot Sport 255/40x18's very shortly. I want to get rid of or, at least reduce the tramlining and I have researched 235/45, 245/45 and 235/50. I have the 8 inch wide asteroid wheels.
The 235/45 will have a 1.2% change in speedo and odometer readings, a sidewall height increase of 0.15 inches and a circumference increase of 0.9 inches
The 245/45 will have a 2.5% change in speedo and odometer readings, a sidewall height increase of 0.32 inches and a circumference increase of 2 inches
The 235/50 will have a 4.7% change in speedo and odometer readings, a sidewall height increase of 0.6 inches and a circumference increase of 3.8 inches
All the tires I have looked at have had a higher maximum load rating than my current tires, a speed rating of W (270 Kmph max), and have a rim width range that includes 8 inches.
Has anyone put a smaller width or higher aspect ratio tire on an XJR? Does anyone have any recommendations on the tires sizes above? Would the 235/50 be too much of a change?
Any input or suggestions would be appreciated
Old Mar 27, 2010 | 08:04 PM
SteveM's Avatar
255/40/18 is too wide for the 8 inch rims as they come from the factory. I guess they did it for more comfort. I've used 245/40 as well as 235/45 winter tires. Both these sizes are better than stock.
Don't use the 235/50. If the 235/45 is already taller that stock, the 235/50 is more so.
Forcedair1
Sep 8, 2025 01:57 PM
aholbro1
Dec 29, 2024 06:46 PM
smith356
Oct 7, 2015 06:41 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
jaguarbill
Sep 5, 2015 11:43 AM
