AM Radio Electrical Static Noise
Old Oct 17, 2011 | 10:15 AM
rocklandjag's Avatar
Default AM Radio Electrical Static Noise
I am having a problem with electrical static on AM stations. It is electrical static that is audible whenever the car is moving. When I come to a stop the noise stops and re-starts as the car begins moving ( from 1 MPH on up). The static sounds like alternator static but it does not change pitch with engine speed - it is always the same pitch and the same frequency regardless of speed or RPM's.
What is really crazy that when the whole car goes over a rise or dip the noise stops and restarts when the car settles. Individual wheels going over bumps do not cause the noise to stop - as if it is sub-frame movement that makes the static stop.
I have disassembled the power antenna and checked all connections into the radio and all are clean and have good contact.
Any help on solving this is appreciated
Thank you,
philwarner
Oct 4, 2024 01:37 PM
leep123
Sep 26, 2015 04:53 PM
frank regalado
Sep 16, 2015 06:15 AM
tsimms7
Sep 15, 2015 12:43 PM
Burdedw
Sep 12, 2015 10:39 AM
