Another engine failsafe mode problem
Old Nov 2, 2012 | 08:03 PM
Icefire's Avatar
Default Another engine failsafe mode problem
Hi. This is my first post and sure wish it could have been under a better circumstance. I have a 2002 XJR100. Everything was great until this dreaded "engine failsafe mode" first appeared.
I did a bit of research on this forum and realized this is a much discussed problem here, but every instance the codes pulled were very different and it left little to go on. So if you guys don't mind reading through another incident report, I'd like to report my encounter and hopefully someone can strike gold for me.
Error messages: DSC/TRAC not available, engine failsafe, restricted performance
Lights ON: CEL, Brakes (occasionally)
AC unit display: "ER" letters showing, beeps severals times upon accessory power turned on
Engine Codes: 1000, 1637, 1643, 1979(occasionally)
So, can someone shed on light on this particular case?
Old Nov 3, 2012 | 04:40 AM
steveinfrance's Avatar
New battery time. These cars are horrendously sensitive to low battery voltage - and they will still crank OK.
At the very least get the battery tested.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
Old Nov 3, 2012 | 08:20 AM
JimmyL's Avatar
+1 on the battery. Just to throw in related issue, check/clean/grease all the power and ground posts while you're at it.
Old Nov 3, 2012 | 09:32 AM
Icefire's Avatar
I did take the battery to my local autozone and ran a load test. Test showed battery ay 94% rating. Is this good enough?
Old Nov 3, 2012 | 09:38 AM
That's fine. Check the terminals as Jim suggests, also check the battery voltage at the posts with ign on and under the bonnet at the main fusebox feed to make sure it gets through OK.
The starter is on a separate circuit from the electronics.
Please post the readings.
Aranon
Sep 3, 2015 07:56 PM
bwr2
Sep 3, 2015 07:49 PM
lee,lee
Aug 31, 2015 04:35 PM
kesslari
Aug 31, 2015 04:53 AM
roumor
Aug 28, 2015 01:02 PM
