Antenna grinding noise?
Old Nov 19, 2015 | 07:48 PM
Pilotman11's Avatar
Default Antenna grinding noise?
Hello everyone! For the past 3 weeks or so, almost every time my antenna tracts upward or retracts downward, I hear a grinding noise when it's all the way up or down. About a week ago, I applied the specialty antenna wipes and grease which did help but the problem didn't go away. I suspect it has to do with the motor; either it needs cleaning or something is jammed. Whenever the antenna is fully up I notice that an inch or so of the antenna seems to get stuck and won't fully go up.
Any suggestions? If so, how would I go about removing the trunk lining so I can get to the motor?
Thanks!
- Pilotman
Old Nov 19, 2015 | 09:48 PM
XJR Pilot's Avatar
The teeth on your antenna is worn out. The motor is pretty hardy. You need to replace the antenna with a new one.
Just undo the chrome nut to the antenna, turn on the radio until the entire antenna pops out, put in the new antenna feeding in the antenna with the teeth in the same orientation as the old one, shut off the radio, let it retract and reinstall the chrome nut. A 3 minute job. No need to even open the trunk. Get the replacement antenna here:
Amazon.com: AntennaMastsRus A241 Jaguar Power Antenna Mast: Automotive Amazon.com: AntennaMastsRus A241 Jaguar Power Antenna Mast: Automotive
Old Nov 19, 2015 | 10:44 PM
Pilotman11's Avatar
Thank you XJR Pilot! I do have one question; is the chrome nut easy to take off? I've heard of people having issues when trying to do the same process. Thanks again!
- Pilotman
Old Nov 20, 2015 | 12:29 AM
XJR Pilot's Avatar
- Pilotman
Unscrew with an adjustable wrench. It will slowly come out of the rubber bushing. Very easy!
Old Nov 20, 2015 | 03:39 AM
....... is the chrome nut easy to take off? I've heard of people having issues when trying to do the same process.
Put masking tape on the surrounding bodywork just in case the wrench slips. The contact area on the chrome nut is very shallow.
Old Nov 20, 2015 | 07:49 AM
MyJagIsGreen's Avatar
I just did this, a 14mm wrench will take the chrome nut off if my memory is correct. There is a white plastic chord the runs the length of the antenna mast. When you take out the old one, double check and make sure the one you take out is the same length as the one you are putting in. On mine, part of the plastic chord broke off inside the motor. If that happens you need to open up the motor and remove the broken piece, otherwise the antenna will not retract all the way. It is really easy to do.
check out this youtube video for help.
Dean9785
Mar 21, 2016 08:21 AM
Swagguar
Nov 3, 2015 04:29 PM
D.K
Nov 3, 2015 12:09 AM
brgjag
Nov 1, 2015 10:18 PM
Johnken
Oct 30, 2015 01:02 PM
