anyone on here had an XJR100 with side marker lights?
Old Jul 4, 2012 | 12:43 AM
jaguars4r's Avatar
Default anyone on here had an XJR100 with side marker lights?
Has anyone on here had an 02 XJR 100 with side marker lights either from Nevada or Connecticut/ east coast area?
Old Jul 4, 2012 | 11:36 PM
Stu 1986's Avatar
When you say side markers, do you mean the ones mounted on the bumper corners, or the side repeaters mounted on the wings as part of the indicators/turn signals?
Old Jul 5, 2012 | 12:01 AM
jaguars4r's Avatar
side markers meaning the ones on the fender, NOT the corner lights by the headlights.
Old Jul 7, 2012 | 01:29 PM
vincent661983's Avatar
I think all X308 included XJ100 in North American market came with that leaper fender emblem instead of fender turning signal markers
note: but I retrofited mine with OEM euro-fender turning signal markers
Old Jul 7, 2012 | 02:41 PM
yeldogt's Avatar
my 95 vdp had them and I tried to have them installed in my 98 -- I was told that it would require relays because of the lamp module and they would not warranty the setup -- I believe one side has the wires. I do not think any of the US x308's had the lamps
Old Jul 7, 2012 | 03:51 PM
plums's Avatar
It only really requires relays on the X308 if you want them to act as both running lights *and* flash. That setup requires 2 relays per side, as well as a bunch of protective diodes. Otherwise, they can be tied into the front turn signals. If you use LED's instead of the incandescent 194/168 the extra draw is nominal.
Old Jul 7, 2012 | 04:12 PM
Boomer from Boston's Avatar
So, do the X308s have any of the wiring needed to use lamps instead of leapers?
Old Jul 7, 2012 | 06:54 PM
yeldogt's Avatar
My memory is ... they were turns only....... I believe only one bulb. I really liked them and the absolutely worked when you wanted to change lanes -- very easy for other drivers to see.
Plums -- With the advent of LED's I bet this would be an easy retrofit today. Evidently the small bulb (168's ?) were enough of a draw on the module to cause problems back in 1998.
Old Jul 7, 2012 | 07:13 PM
plums's Avatar
The draw on the wedge incandescent bulbs is about 5 watts. Just looking now, a LED runs 1.5 watts.
The only concern with running the incandescent in combined running/signal lamp mode is the small air volume available for heat dissipation in continuous usage. In signal lamp only mode, it would not be a problem at all.
The shop probably just did not want to do it and came up with some plausible reasons to get you to back down.
Running the side lamps in combined mode makes the car more visible at all times, and still retains the benefits of signaling coming out of driveways as well as for lane changes and when the car is seen at an oblique angle.
There is also a high mounted brake light flasher module awaiting install
There are now even more dimwits with their heads down attending to their phones today than in 1998.
Old Jul 7, 2012 | 07:17 PM
plums's Avatar
Only on the RHS. It is clipped to the leaper badge when you remove it.
Not worth worrying about, just tie it into the existing turn signals. That will involve pulling back the wheel arch liner to install the wiring as well as fishing the wires through to the turn signals. Think coat hanger and electrical tape.
New ones will come with the bulb holder and bulb.
They are known as "directional repeaters" when searching on ebay.co.uk
The going price is about $25 each or a bit less.
Old Jul 8, 2012 | 11:10 PM
jaguars4r's Avatar
the reason I asked this was b/c I recently bought an XJR100 and would like to know if it was anyones from the forum. It has the side marker turn signals so I figure its some enthusiast that installed them and is on the forum. Car originally came from Florida and in 2007, it went to Las Vegas but somehow ended up in Connecticut
Old Jul 9, 2012 | 12:26 PM
https://www.jaguarforums.com/forum/x...version-74468/
I attached some photo of the side-maker/turning light retrofit
Old Jul 12, 2012 | 09:19 AM
adam699's Avatar
Congrats Nick,
Hopefully this one doesn't have any cooling issues. Post up some picks!
Adam
Old Jul 12, 2012 | 09:53 PM
jaguars4r's Avatar
yea, i really hope so too... lol
Old Jul 16, 2012 | 07:08 AM
Sy1664's Avatar
Just a note for you guys in the US - the lenses for the trunk are exactly the same shape, but clear. I have changed my repeaters to the clear type and then used an amber bulb, I personally prefer the look.
Just another option?
99xk8guy
Sep 29, 2025 10:51 PM
Jpav27
Jul 31, 2022 06:43 AM
mbergen
Oct 23, 2019 10:26 PM
redrover41
23
Sep 25, 2015 01:33 PM
KarimPA
Sep 12, 2015 08:15 AM
