is that the bad alternator
Old Feb 18, 2026 | 12:37 PM
vincent661983's Avatar
Default is that the bad alternator
Hi, Guys
I am having issue to start up my XJR. already replaced the starter and battery but car still could start up without a battery jump. once I connect it to the jump box, it will start update right away and it runs just fine.
alternator is about 11 years old..any thought about it? I think it went bad
Old Feb 18, 2026 | 02:26 PM
Vauxi's Avatar
Where you connect the jump box ?
Old Feb 18, 2026 | 07:58 PM
Parker 7's Avatar
About the only way the alternator is affecting the starter voltage is if the internal to alternator voltage regulator is under voltage but you would think you would see a alternator / charge light
The large B + terminal battery cable output on the Alt should put out 13.5 minimum to 14.5 volts which the auto parts store can measure for you , a fully charged battery is around 12.75 volts
There are some connectors shortfalls that can affect the delivery final voltage from battery to starter :
Bus protection module ( mega fuses terminal nuts get loose and they do )
False bulkhead connector under hood , someone posted some good pictures lately
Never overtighten the battery positive post bolt , splits nut underneith
Panarabica
XJ40 ( XJ81 )
24
Jun 23, 2024 05:00 PM
nail24fac
Jun 15, 2021 11:10 PM
Mitsuki
Dec 25, 2018 12:18 PM
jmault
Aug 28, 2012 02:45 PM
raw13
XJ40 ( XJ81 )
Jan 5, 2009 08:10 AM
