Battery hook up Issues if done wrong
Old Jan 20, 2015 | 08:51 PM
dave308's Avatar
Default Battery hook up Issues if done wrong
I have read over and over Not to mess around when hooking up the battery , but what I need to Know is if you DO and my friend DID while helping me , What Exactly does it Damage as the car is now Wacked , engine runs Please Help
Anybody Know what modules store the VIN
He hooked and Unhooked the Battery cable many times in a couple of minutes
I posted earlier but am trying to Simplify the Problem Thank You
Old Jan 20, 2015 | 09:31 PM
test point's Avatar
What are the symptoms of the problem?
Most systems are protected but you can overcome any protection.
The ECM holds the VIN data.
Please post a picture of Elroy!
Old Jan 20, 2015 | 09:53 PM
dave308's Avatar
what is a Elroy , I very much need to talk to a expert , Instruments dont work , Long list I will Gladly Pay to talk to someone who knows this stuff
Old Jan 20, 2015 | 09:59 PM
dave308's Avatar
OK check engine light ,fail safe engine ,amber light on ABS on , Brake on, Incorrect part fitted , trans in fail safe and Instruments do not work , I have changed many parts as I have a parts car , except the ECU for engine as the code is wrong for the ones I have , Question , I should be able to change any other module except ECU as long as they have the exact part # is that correct and if I purchase another correct ECU why would the VIN matter if no other modules store it ??
Old Jan 20, 2015 | 10:53 PM
Mark SF's Avatar
I don't understand why you've started a second thread for the same problem.
Old Jan 20, 2015 | 11:03 PM
dave308's Avatar
i was hoping to simplify the problem Sorry how do I delete it It thought it was a Valid Question that needs an answer , first time on here or any Forum , I was asked to list the problems , my original question was about battery hook up ,, Please correct my Grammar and Spelling as well as I will make more mistakes
Old Jan 21, 2015 | 12:29 AM
plums's Avatar
a) you need to describe in great excruciating detail what you mean by "hooking up the battery wrong"
b) put all the original modules back and try a hard reset, unless of course you know a particular module is damaged
use line breaks.
Old Jan 21, 2015 | 12:54 AM
dave308's Avatar
we did all that and a hard Reset over and over ,bought the car with a no start issue ,original problem with car was water in gas tank, found the cause for that so we drained the tank replaced the fuel pump , removed schrader valve on engine as we knew the line was full of water as well
, my buddy turned on the key and used the battery terminal to cycle the fuel pump and pump out the water , he would touch the Battery terminal over and over to cycle the pump
, replaced valve and started engine , runs fine ,but all those problems showed up , then he told me how he had cleared the lines , Then I read about how that was a Bad thing and my question was what does it damage Thank You
Each module replaced with a hard restart that showed no change was put back original , body module ,trans, instrument cluster, so far , I feel if I could get the Gauges to work the problem would go away dont have correct engine ecm I have 2 with the wrong part # not tried them, to test with Thank You
Old Jan 21, 2015 | 09:03 AM
motorcarman's Avatar
'JUMPING-THE-RELAY' is the better way to run the pump continuously without starting the engine.
As I stated in the other thread, You will need to interrogate ALL the modules to see if any have a DTC or has NO-COMMUNICATION. (damaged?)
bob gauff
Old Jan 21, 2015 | 09:05 AM
JimmyL's Avatar
A low battery will cause many electrical issues. Also, grounds and power points that are not making good contact will do the same. This is especially possible with a car that has been sitting for a while. There are many posts in the archives of people who have chased problems and expected the worst when the problem was a dodgy ground, power connection or a low battery.
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
OkieTim
Sep 2, 2015 12:48 PM
