blew a hole in my intake manifold??
Old Dec 7, 2010 | 10:46 PM
johnny screwdriver's Avatar
Cool blew a hole in my intake manifold??
apparently I blew a hole in my intake manifold when the secondary chain broke on a-bank. Is this common? Also need to know if the aj27 manifold is inter-changable with the aj26 and if so. what mods are needed.
Old Dec 8, 2010 | 12:23 AM
3870x2's Avatar
The chain braking is common, if that is what you mean. From what I hear, a great many things can go wrong when a chain breaks.
Old Dec 8, 2010 | 04:14 AM
sparkenzap's Avatar
johnny:
the AJ27 engine has different VVT controls, different intake manifold bolt patterns, I believe a different flywheel and a few more. I believe if you get the complete AJ27, with the parts you havwe from your AJ 26, you can make itr work. See posts here and in the XK forum by AVOS. He apparenly has done an XJR swap, and notes what he thinks it takes for an XJ8. The XJR does not have VVT, so that makes the XJ8 more complicated because the cam sensor arrangement changed between AJ 26 and AJ 27.
Old Dec 8, 2010 | 07:31 AM
Brutal's Avatar
Its not uncommon to blow a hole in the intake since when a chain breaks or the engine goes out of time, it can fire a cylinder with the intake valves open and combustion in the intake is never good
Old Dec 8, 2010 | 10:59 AM
Hi ross, it's good to hear from you again and thanks for your useful info. john.
Poet
Feb 7, 2025 02:18 PM
MrWhite
33
Oct 22, 2015 10:29 AM
Johncy2000
Oct 2, 2015 01:05 AM
BSM
Sep 25, 2015 05:00 PM
