Bonnet Liner Replacement
Old May 29, 2020 | 02:27 PM
Gator8's Avatar
Default Bonnet Liner Replacement
I posted this in the “What did you do to your X308 today?” thread, but I thought I should also start a new thread to make it a little easier to find. My 2001 XJR’s bonnet liner was rather tattered. Since a new factory one cannot be had, I bought a 65” by 48” by 0.5” batt of hood insulation material from a performance parts house. I removed the old liner and saved the plastic screw rivets. Using the old one as a template, I cut the new material, and just to be safe, I cut about an 18” by 25” piece from some thinner hood insulation I had bought and glued it (using 3M Super 77 spray) to the area directly above the supercharger. I tried to attach the new material with the screw rivets, but quickly found that they pulled through the insulation, so I resorted again to the Super 77. I also found I could repair any defects by cutting and gluing a patch using the spray adhesive.
The result is a definite improvement in appearance, and when I drove the car, it was noticeably quieter. Even better, when I got home, the bonnet was cool to the touch (the ambient temperature was about 80 degrees), except along the edge where the insulation does not reach. My only word of caution is to get it in the right place the first time, because once it touches the bonnet, it adheres—permanently!
Old liner in place
I cleaned the underside of the bonnet thoroughly and let it dry overnight
The old liner, which I will save as a template in case I ever need to do this again
New bonnet liner
swingwing
Aug 7, 2020 07:54 AM
Gator8
Apr 16, 2019 02:06 PM
Dukejag
Mar 15, 2019 11:10 AM
caferacer
Mar 21, 2017 08:00 PM
worrasf
Sep 1, 2014 10:10 AM
