Boot open light is on even when boot is closed
Old Jan 8, 2012 | 06:55 PM
therobesons's Avatar
Default Boot open light is on even when boot is closed
My car has been possessed by a poltergeist, with lights, locks and stuff locking and unlocking, turning on and off by itself and now my remotes don't work, can open the trunk or lock the doors or even open the fuel door. With the help from this forum I suspect the Security Locking Module for all this, but now the "Boot open" light on the dash is on.
Is it maybe the same issue (SLCM) or has the boot open switch stopped working at the same time. Coincidence?
Where is the Boot open switch and can I check to see if it is good, or do I just replace it?
Bob
Old Jan 8, 2012 | 08:22 PM
sparkenzap's Avatar
I am fairly sure the switch you are looking for is in the boot lock assembly. I would check the wiring harness that is along side the right side trunk hinge, They are known for fraying (look closely) and could cause at least some of your symptoms.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
King Charles
Sep 3, 2015 12:40 AM
