Boot (Trunk) Open, Hard Reset.
Old Oct 13, 2016 | 04:20 PM
omgimali's Avatar
Question Boot (Trunk) Open, Hard Reset.
Hi,
I own a 2001 XJ8 and there is a warning message that says BOOT OPEN in the instrument cluster. So the solution was change the Microswitch in the boot, so I did. The message is still there. Do you think doing a Hard Reset to the battery would clear the message? And how would one do a hard reset?
P.S. the battery has been tested and is in good condition.
Thanks,
Ali
Old Oct 13, 2016 | 05:30 PM
nilanium's Avatar
check the trunk wire loom for broken wires, it is a bundle of wires that goes through the US passengers side trunk hinge arm.
Old Oct 13, 2016 | 05:43 PM
King Charles's Avatar
Hard Reset instructions via "SuperSport"
https://www.jaguarforums.com/forum/x...85/#post605000
Old Oct 14, 2016 | 11:09 AM
yeldogt's Avatar
Are you sure the switch was bad ... it could be a wire. If it was a wire you have not fixed the problem ..... never heard of needing to do a hard reset for the trunk
Old Oct 14, 2016 | 06:06 PM
omgimali's Avatar
Unhappy
I dont know but i checked the wiring loom on the us passenger/uk drivers side and there were no frayed wires...
Old Oct 14, 2016 | 06:57 PM
yeldogt's Avatar
The wires fail from bending and being pulled as the trunk opens/closes -- the insulation shows no damage. You have to test the wires along the length. I had to remove the cover on the back of the trunk. My lights failed and the fault was a few inched down behind the cover.
Old Oct 14, 2016 | 07:04 PM
omgimali's Avatar
Is it hard to rejoin the wires or solder the wires? can it be a diy job? dealer or mechanic?
Old Oct 14, 2016 | 07:18 PM
yeldogt's Avatar
Very easy --- get one of the cheap multi testers from harbor freight. to test the wires and future use. HF often has coupons where you can get them for free ... and pick up a cheap scanner from them or amazon $30. the two items are invaluable with an old car.
I was able to move the wire loom around and all I did was twist in a short wire splice -- soldered it together and slipped a section of heat shrink tubing. Slip on the heat shrink tubing prior to twisting the wires together. You can get cheap soldering irons with solder for $10. The heat shrink is only a few dollars for a sample pack.
You may be able to have someone push the trunk button as you flex the wires.
Old Oct 14, 2016 | 07:39 PM
omgimali's Avatar
Alright then! thank you so much really helped me out!
elindo
Apr 10, 2023 07:27 AM
AlanWiedie
E type ( XK-E )
Oct 27, 2016 03:44 PM
sherbercars
Oct 1, 2016 02:29 PM
ZappaMaster
Sep 21, 2016 12:18 PM
Plastic Paddy
Sep 19, 2016 08:53 PM
