!! Brake Job 98 XJ8 !!
Old Aug 10, 2008 | 05:17 PM
atom069's Avatar
Default !! Brake Job 98 XJ8 !!
Anyoneknow the exact tools sockets etc required if possible. **It wont let me post more than one sentence
17mm socket for caliper bolt, but whats the allen wrench holesize onthe caliper pin?
EDIT*** It's a 7mm allen for that caliper pin...if anyone wanted to know. I had no clue, my buddy is doing hisBRG 98 first brake job.
Old Aug 10, 2008 | 05:18 PM
atom069's Avatar
Default RE: !! Brake Job 98 XJ8 !!
Hey guys, I checked the forums but came up with nothing (if there is a thread, perhaps direct me that way, my apologies)
Old Aug 17, 2008 | 08:34 PM
oldmots's Avatar
For a brake job, I usually end up with all sorts of things lying around. If you have a normal tool complement, you should be okay. The guide pins require a 7mm allen wrench, which does not come in most sets. I have brake cleaner, rags, AeroKroil spray or PB Blaster, 17mm socket , pliers and screwdriver for the rattle spring,piston compressor or large C clamp, mallet (heavy rubber). One thing I suggest, a car as old as a 98 should have brake hoses replaced as well, requiring bleeding the brakes. Brake hoses are cheap and well worth changing.
Old Aug 19, 2008 | 09:54 AM
atom069's Avatar
yeah mines complete now. The factory had the slotted/drilled rotors mislabeled, it appears that the slots are to lean towards the back of the car for that manufacturer. My right front brake hose is wearing off the first layer of shroud on a small spot, so I will be replacing them all very soon. I saw a metal set for $40 for this car. Might pick that up. Thanks
dsnyder586
Dec 29, 2024 07:39 PM
jdzubas
Oct 4, 2015 09:14 AM
Jefro
Sep 15, 2015 01:44 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
