Brake lights operation/ignition key
Old Dec 16, 2014 | 03:29 PM
VDP1999's Avatar
Default Brake lights operation/ignition key
I own a 1999 VDP and noticed that when the key is not in the ignition the brake lights do not go on when I step on the brake peddle. I can't find anything in the manual on whether this is how the brake lights are suppose to operate. Does anyone know if this is the correct operation.
Old Dec 17, 2014 | 11:05 AM
andrew lowe's Avatar
My 98 XJR is the same, why do you want brake lights without the key in the ignition ?
Old Dec 17, 2014 | 10:02 PM
jimlombardi's Avatar
Our 2001 XJ8 also works the same way. No brake lights with brake pedal applied until key is put in and turned to position 1, or after engine is running (either operation).
Jim Lombardi
Old Dec 18, 2014 | 11:06 AM
VDP1999's Avatar
Thanks for answering my post. I do not need the brake lights to go on when I step on the brake with the key out, I just thought it was strange since with my other cars (not Jaguars) if you step on the brake the lights go on. I want ed to be sure I did not have an electrical problem
philwarner
Oct 4, 2024 01:37 PM
mbergen
Oct 23, 2019 10:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
KarimPA
Sep 12, 2015 08:15 AM
My Pham
Sep 4, 2015 03:37 PM
