brake pulses
Old Sep 3, 2014 | 04:01 PM
ant17's Avatar
Default brake pulses
Brought the car to be checked for the brake issue.
Pedal seems like abs kicks in when stopping but not always.
The diag showed a rear hub sensor???
Is that the little wire that has 1 bolt holding it?
doesn't seem to hard of a replacement.
ap
Old Sep 3, 2014 | 04:37 PM
andrew lowe's Avatar
That sounds like it, one bolt to undo, one plug to undo, twist and pull out, it is a small electro magnetic sensor. Now as all the best manuals say, replacement is a reversal of removal.
As long as nothing is seized up or shears off, the hardest part is jacking up and removing the road wheel.
Old Sep 3, 2014 | 07:57 PM
RJ237's Avatar
The sensors do not often fail, but may need cleaning. The connecting cable does fail more often due to flexing.
Old Sep 7, 2014 | 05:52 AM
Bjag's Avatar
Is there a ring on the axle that the sensor reads if so check it .
Old Sep 8, 2014 | 05:41 AM
ant17's Avatar
No, just an axel wheel-gear.
PMKimpton
Aug 3, 2019 08:22 PM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
