break down
Old Aug 24, 2017 | 11:26 AM
El Tel's Avatar
Default break down
xj8 driving 50 ish in traffic, hit the motorway and tried to accelerate. engine died, immediate thought was fuel pump/relay. got recovered changed pump still will not start???????????
no codes showing
turns over fine
Old Aug 24, 2017 | 02:14 PM
RJ237's Avatar
Do you have fuel pressure at the schrader valve on the fuel rail? Knowing the year and number of miles may help.
Old Aug 29, 2017 | 08:27 AM
El Tel's Avatar
no fuel pressure, power to pump though
noticed throttle body buzzing?
another thread mentions TBs causing this problem
Old Aug 30, 2017 | 05:26 AM
Sean B's Avatar
A TB fault should always post a fault - I had a no start recently, signal to fuel pumps good, spun over, no fuel pressure - thought pumps but it turned out to be the engine coolant temp sensor. This doesn't give a code so look at this part before the TB.
Old Aug 30, 2017 | 08:05 AM
El Tel's Avatar
Default no fuel pressure
Sean
just ordered another sensor
i hope it works
Old Aug 31, 2017 | 06:57 PM
tahoemedic's Avatar
Dumb question but did you check the fuel filter to make sure it's not plugged up? Usually if you're able to cruise at low speed/low fuel consumption you can get by until it's fully clogged, then no fuel to start afterward.
