Broke timing chain
Old Aug 24, 2009 | 03:28 PM
loudjag8's Avatar
Default Broke timing chain
i just found out today my timing chain broke i think its the secondary one which is the shorter of the two i think but its on the drivers side...how screwed am i now that this has happened?? I didnt drive it with it broken that i know of because the car ran awesome, turned it off in a drivethru and then it wouldn't start back up.. Is there any possible internal damage if it wasnt run??
Old Aug 24, 2009 | 04:14 PM
JagtechOhio's Avatar
The secondary (short) chain is always the one that breaks, and the resultant damage can be easily assessed but not predicted. Since the engine was not running at speed when the failure occurred, you may not have bent any exhaust valves when the exhaust camshaft stopped turning. You can remove the broken chain, remove the exhaust camshaft, and crank the engine over to perform a compression test without risk of further damage and to find out if any exhaust valves are bent.
Old Aug 25, 2009 | 01:25 PM
loudjag8's Avatar
i got a upper chain replacement kit with the master link in the chain..how will i know if the cams are back in place so i dont break or bend some valves??
Old Aug 25, 2009 | 01:46 PM
H20boy's Avatar
I'm not sure that is a short and simple answer loudjag. Is it on?
I typed more, but chose to leave that opinion out of the reply.
Old Aug 25, 2009 | 01:58 PM
Loudjag, the answer is either by researching the topic on this or another Jaguar site, or buying the service CD, and then by acquiring or fabricating the necessary special tools to set the camshaft timing. You could also ask the guy who you spent your money with.
Wolfy
May 28, 2024 08:06 AM
RoyLittle0
May 25, 2023 02:38 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Bowman
Sep 15, 2015 06:54 AM
Bowman
Sep 3, 2015 03:17 PM
