Buying an XJR....Help please.
Old Sep 21, 2008 | 10:48 PM
stkxjrtech's Avatar
Default RE: Buying an XJR....Help please.
get everything checked over, make sure to check engine compression also. If everything checks out ok my opinion would be go for it if the price is right.
Old Sep 28, 2008 | 10:46 PM
Brutal's Avatar
if he changed the oil every 5k with mobil1 or 3k even better being sc your ok, but if the updated secondary chaintensioners have not been installed do it now before you end up buying an engine, theyre metal bodied instead of plastic.This engine is replaced(all v8 actually) most often for tensioner/chain failures which many times results in catastrophic engine failure. Nicaseal just doesnt like dirty oil and leads to excessive oil blowby in the intake track and plugging of the part load breather thatll lead to stalling and fuel fouling the plugs and oil rings on cold start giving you and engine that cranks but wont start
Zimbomac
Apr 7, 2019 10:56 AM
CClifton
Mar 19, 2017 02:25 PM
Bret_T
Oct 9, 2016 08:07 PM
powerhouse
Sep 18, 2015 11:12 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
